how to take off fender liner screws??
Hi, im trying to install jdm sidemarker on my 96 civic, the only problem i have so far is to take off the fender liner so i can do the wiring. I've cut the hole on fender successfully, but i am having difficulty removing the fender liner screws. just wonder how to take them off? or is there another way to do the wiring? thanks.
Re: how to take off fender liner screws?? (Ksoulja)
Prepare to buy some new ones cause I break almost all of them every time i take it off. There is a tool that body shops use which gets em out, but usually they become brittle and break when forced with a flathead
Same here-
I changed a fender on my civic yesterday, and the fasteners are the type you pry the middle up. They are a bit smaller than the type on the grill.
One of mine broke, and on all but one of the others I had to pry them out entirely, then take them apart afterwards.
Re: (YNG)
ok, i got the fender liner remove, the problem now is how do i wire the sidemarker? i've got a red and black wire from the sidemarker, and there are 3 wires run in the turnsignal.
Seagull Management
Re: (ShinotakuX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShinotakuX »</TD></TR><TR><TD CLASS="quote">did you guys use soldering or splice connector? </TD></TR></TABLE>
You could do either, but personally i'm very partial to soldering and putting shrink tubing over the top, do it right once and never look at it again.
i_VTEC
09-15-2008 03:24 PM
trevorjohn88ef
03-30-2008 10:10 PM
TypeR1558
01-12-2003 10:22 AM
