Help Vtec and spedometer aren't working/ check engine light
My speed sensor isn't working most likely, it works intermittently, i changed it three weeks ago and now it completely doesn't work. CAN I TEST THESE SENSORS ON SOMEONES CAR? I have a jdm b16a in a 98 ex. thanks
yeah I know b and d series speed sensors are the same.
find out what code you are throwing - probably for speed sensor - correct that whether it is connections or the sensor.
Wheres my titleeeee!
Re: (DTA-Zombie)
pull the plug off of the speed sensor and spray electronic plug cleaner in there .. or get a flat head and just clean off the spades. I used to have the same issues on my B16 A .. Does the speedometer sometimes bounce even when you are at a stop. Mine used to do that. I replaced the speed sensor 3 times. My final fix was taking the cotter pin out, making sure the gear was ok, cleaning the plug inside and out (theres a little spring inside be careful not to lose it) and then just putting it all back up together!!
Re: (choadtx)
yeah, i disconnected it and jiggled the wires last night and its working on and off. i changed the sensor and it didnt fix the problem, ill try that spray and take it apart. yeah the spedometer jumps constantly.
Re: (1player2nv1)
Your adice on Cleaning the plug outlet is working so far...the spedo doesn't jump, check engine light is off, and VTEC works finally consistently. thanks
madnad
09-18-2018 06:49 AM
