what is P1503?
Re: what is P1503? (chickenwing)
How did you obtain said code?
You can only get "P" codes with an OBD-II Scanner (meaning your car has to be A) Scanned with an OBD-II scanner, and B) '96 or above). You can't use the jumper thing to obtain P codes, only standard OBD-I codes. So you should know exactly what it is because it should tell you on the screen...or if you have one of the cheap *** ones that won't tell you, you read it off the scanner wrong.
I would say check again. I dont know what vehicle you have but I put in a few diffrent ones 96 and up and none of them carry a p1503 code.
Re: what is P1503? (gsrhatch2356)
yes it is a canadian 1997 civic ex sedan model.
it originally comes with a Y7 but I just swapped in a Y8
i used this innova obd2 scanner
dookeye
01-24-2010 11:53 AM
ensracer
10-31-2004 08:07 AM
