Idle Drops/Struggles When Headlights Are On. Help Me Find The Culprit!
1 Post
Video: (Sorry it's a bit out of focus but I think you can still see what's going on. Towards the end, it actually drops low enough to stall the car.)
http://www.youtube.com/watch?v=C4LKaQ1fNfw
Alright, I need help figuring out what the culprit is that's causing this:
My idle doesn't seem to hold when the headlights/foglights are on. For example, night driving.
When I reach a stoplight and sit there, the idle starts to struggle, sometimes dropping as low as near stall where the cluster lights dim.
The idle also seems to be affected when I'm holding down the brakes. If I release the brake pedal quickly, the idle surges back up.
Anyone have any idea what's causing my idle to drop? It seems electrical somewhat? Since it seems to occur more frequently when the headlights/foglights/brake lights are on.
Re: Idle Drops/Struggles When Headlights Are On. Help Me Find The Culprit! (fms1day)
IMO could be your battery conections. and or ground cables....
take off your battery wires and clean them really good with a wire brush and put some dieelectrical grease on the terminals to keep them from coroding up. and if your ground wire has any green on the wire around the rubber coated areas then replace the wire! the corosion is on the inside of the wires.
dont forget about the front motor ground and side tranny ground wires. those 2 wires always seem to be striped back and easy exposed wires for dirt and rust to hurt current flow.
and if all of the wires and conections look good then take your car into a autoparts store that does free alternator/battery tests and have your alternator and battery tested out and replace if weak.
live4soccer7
13
10-12-2022 02:38 AM
95_Civic_4dr
12-13-2009 09:14 PM
PINKS
19
07-25-2006 03:47 PM
