IACV problem
IACV problem
Hi everybody, i have a problem with my IACV: when i plug it the rmp go down very slowly when i left the throttle and some times the car idle at 1500rmp, when i don't plug it the car runs fine. I have cleaned it and the problem isn't solved. Now my question is: if delete it is going to change something or it is just a bypass for the problem? How fuel economy will be?
Thanks.
Thanks.
Re: IACV problem
IACV is only in use during idle. DId you clean the IACV gasket/screen when you removed it?
Pull a IACV from a salvage yard and see if solves the issue. Also, clean the throttle body and do a smoke test for vacuum leaks.
R. Mack
06-01-2005 07:55 PM
rice a roni
12
05-24-2005 12:31 PM
