U joint for manual rack
Re: U joint for manual rack
96 Honda del sol si that had oem power steering. I got into an accident recently and bought a manual rack and pinion. The rack bolted on perfect but it doesn' connect to steering wheel column joint cause it' thinner then the power steering.
Both the pinion gear shaft and the column's coupler have splines. These splines serve a safety purpose as well as a funtional purpose.as they ensure a solid connection even if the coupler bolt were to loosen.
Are you sure you ordered the correct rack? Is it an aftermarket or Honda genuine rebuilt rack? Call the company you ordered it from and tell them the issue...maybe the have splined shims or will send you a better fitment rack.
Possibly, a 5th gen Civic's coupler might work?
IIRC manual racks were only used until 1992 (5th gen civics) this may explain the difference in pinion shaft circumference.
I fully de-powered my car's ('95 Civic EX coupe) steering rack a few months ago. Completely de-powering requires removing the rack internals and cut off a metal seal to eliminate air pressure. I contemplated purchasing an aftermarket manual rack but I was concerned with fitment issues and it only cost me $10 to replace a worn out needle-bearing the pinion gear rotates on. I ended up purchasing new inner and outer tie rods and boots as well.
You will have to get the manual rack u-joint from a salvage yard.
Manual and power steering had two different size yokes.
It's been stated in a few manual to power or power to manual write ups that you need the u-jount/yoke for the rack you are installing. If it weren't for that, I would never had known.
Or maybe it was in a adding tilt steering column write up.
Don't really remember but do remember reading about it so I kept the 95 tilt power rack u-joint/yoke with the column when I pulled it.
Here we go, a couple of posts from others who noted and had response as such:
https://honda-tech.com/forums/honda-...joint-3272161/
https://honda-tech.com/forums/honda-...olumn-2137012/
blackGSRcoupe94
07-25-2010 07:53 PM
