Christmas idle issues
Hey all, merry christmas.
My Del Sol has been doing some weird stuff.
1. Idles fine on start/cold idle.
2. When it warms and idle drops, it'll misfire randomly, with varying severity, and some times die completely. Sometimes it'll idle fine for five minutes, and just putt once or twice, some times it'll choke and recover, sometimes it'll choke and die.
3. Doesn't surge/hunt at all.
4. On power for the most part it runs fine, sometimes at low rpm/high load, it'll cut out once or twice but that's it.
5. Already swapped plug wires for some NGKs I had laying around.
I suspect a spark issue but I haven't heard of ICMs or coils having intermittent issues like this.
Sticky injector?
Sticky injector?
Re: Christmas idle issues
Sticky injector?
Sticky injector?
What year Del Sol? Engine size? Any mods?
Do a valve adjustment. Inspect the spark plugs for one that looks different from the others, indicating the problem is at that cylinder rather than generalized.
I feel that it's worth noting that I had another civic that ran on three cylinders just fine and never died, so I don't see it being an individual cylinder. Whacky valve lash wouldn't cause a constant problem? Valvetrain is super quiet as well.
I would ohm the injectors out and make sure that none of them are fried. The should all be sitting between 10-13Ohms. I’d also check for any vacuum leaks since the issue only happens when the engine is warm I would suspect that the metal is expanding and causing a pretty good vacuum leak if that was it. I worked on an Integra that had crazy vacuum leaks when the engine got warm but ran perfect when it was cold. We ended up retorquing the intake bolts, putting new injector seals in it, and finally a new FITV
Ya my injector seals were super bad to at one point lol. I couldn’t figure out where the gas smell was coming from in my car and figured I would find it once it got worse. Needless to say after I threw up from the smell being so strong I made it my priority to find the cause
Awesome! I hope the new gasket fixes it! Give me a heads up if it works
tgordenDELSOL
10-12-2014 11:26 AM
lv6l
14
11-28-2005 06:50 PM
pdiddy
12-10-2002 10:47 PM
