Help!! Driverside torque Mount problem
Old 02-27-2009, 07:18 PM
Mr. Em1's Avatar
Default Help!! Driverside torque Mount problem
hey guys i bought my car with a bad torque Mount. I finally got around to purchasing a brand new mount and i went to go take off the old one and I can't get it off because the welded nut inside the frame rusted out. How are you guys going about fixing this problem? I noticed that my motor moves a decent amount more than I would want it to. The rest of the mounts aren't ripped and I would like to replace this asap because I am trying to fix all of my little problems with the car. thanks for the help guys.
Old 07-18-2009, 03:53 PM
racerx43269's Avatar
Default Re: Help!! Driverside torque Mount problem
any answers?? i have the same issue
Old 07-18-2009, 04:14 PM
Resident Gearhead
BryanM.'s Avatar
If the nut inside the frame is stripped, retap it.
If the welds have broken and the nut spins when you turn the bolt, you most likely will have to cut a hole in the frame rail to get in there and weld in a new nut. Sucks, but there's nothing else you can do really.
I had this happen to me, only it was the sub frame. A welded nut for the LCA bolt on the inside broke off. I ended up repalcing the subframe. Pain in the freakin ***.
cmsoard
03-13-2009 01:35 PM
pearl
18
07-29-2005 07:45 AM
singlecam screamer
19
02-23-2005 07:48 PM
s1ngle
06-05-2004 11:26 AM
singlecam screamer
07-30-2003 05:22 PM
Quick Reply: Help!! Driverside torque Mount problem
