ITR pistons in b16
ITR pistons in b16
ok i've heard that itr pistons would actually lower my compression. so i was wondering if this is true of the jdm pistons or if its only the usdm version that lowers the compression. thanks.
Crazy Honda Guy
Re: ITR pistons in b16
The answer is yes, it "will" lower your compression. A B16 piston has a higher dome than ones found in a B18C5
here's a link that will help others out, it been around for years....
http://www.c-speedracing.com/howto/c...c/compcalc.php
well the reason i ask is because there is a rebuild kit on ebay that comes with itr pistons for $270. im not trying to increase power i just dont wanna lose much... so could i tell the difference if i did this? thanks
um, you really wouldn;t feel a major difference between pistons, i personally reccomend JDM p30 B16 pistons, but you really wont loose much with ITR pistons
