Creaky noise at the front end.
Hello.
I have a 2000 civic EX 2dr which is 135000 on it. It make some creaky noise at the front end (I think) from the last month when I drove the car on the local load and highway. Not quiet lousy but it is repeated continually. What could be a problem?
Also I have a set of coil spring and strutes from 2003 RSX type-s which was my bro. Can I replace those parts for my civic?
Thanks.
Thanks.
Re: Creaky noise at the front end.
I heard the noise about 2 month ago while the car was running on the highway.
It wasn't noticible but repeated, so I recognized.
Is that the ball joint problem?
Thanks.
Thanks.
I hope the greasing works.. If you want to drop it and go with better springs, you might as well replace it all. ball joints, wheel bearings, struts,etc. I had to do all that and the CV's
bushings... you know, all the rubber pieces on the suspension. Where suspension parts are bolted together or to the chassis, there is always a bushing. Just look for rubber things underneath the car. Grease everything rubber, except the axle boots and tires.
i bet its just your front bumper. bang on your front bumper just below the grille and see if thats the noise you're hearing. i went through the same thing.
94 IntegraLS
01-08-2012 01:03 PM
PhuCDatBiCh
06-25-2008 10:57 AM
