will i or can i pass smog and/or get it bar'd?
history:
96 civic
obd1 92 motor, ZC//d16z6
obd2a wire harness
obd2a EX ECU, P2P
Ive done the CKP sensor // knock sensor trick.
completely stock from head to block and tranny.
will i pass smogg?
and better yet, i wanna bar'd it cause cops down here are insane with any swaps. can i also get it bar'd atleast?
and yes, i know.... if you want to bar'd your vehicle, you have to have the motor within as the same year or newer.
and another thing, if your tranny is manual, and you are running an automatic ECU, will that pass smog or can you bar'd it also? i know it throws a code 19 (automatic transmission lock).
any help gladly appreciated! *thumbs up*
96 civic
obd2a wire harness
obd2a EX ECU, P2P
will i pass smogg?
Re: will i or can i pass smog and/or get it bar'd?
The guys will know a D16Z6 is OBD1 and it likely won't work out, even with OBD2 working and all. In other states it -might- get by. Definitely fix the A/T code with a different ECU though, the CEL will probably be the death of the smog check.
I really do not know what to do in your situation.
bump this! cause i have almost the same setup yet, i have a B series in mines. i might need to do this too! need more thoughts and info please! bump!
history:
96 civic
obd2a wire harness
obd2a EX ECU, P2P
will i pass smogg?
96 civic
obd2a wire harness
obd2a EX ECU, P2P
will i pass smogg?
darksolguy
10
07-15-2008 12:43 PM
91civicEX
19
01-12-2004 06:28 AM
turbo*s2k
12-12-2003 11:19 PM
