VC sealing
VC sealing
I have always dabbed some rtv/hondabond on the corners of the valve cover and have never had it leak. There was a guy that said all u have to do is oil the VC gasket and it wont leak from there. I have personally not put rtv in those corners and it ended up leaking. What are your guys input on that?
Re: VC sealing
Oiling the gasket? you oil it so it doesn't dry up and crack like on oil filters. i always put RTV on gaskets for valve covers and they never leak.
Re: VC sealing
It specifically states in the shop manuals to put Hondabond HT on those 4 corners to prevent leaks. Also, if you had noticed when you removed the old valve cover gasket that there was Hondabond HT on those 4 areas. It is highly recommended that you Hondabond HT those areas when putting a new gasket on to prevent leaks.
Re: VC sealing
Do yourself a favor and stop at the dealership and pick up a tube of Hondabond HT. If you want to go cheaper, Permatex Gray is nearly the same, but not as good in my book.
