O2 Sensor question
O2 Sensor question
I have a 99 civic ex and just got a tsudo catback put on it and now my check engine light is on and i read the code and its the o2 sensor. So do you guys think that maybe the fried my 02 sensor when they were using the mig welder or do you think i just need a dummy sensor? Thanks for any help
Re: Help!!!
alright my bad sooooo can anybody help me
Re: Help!!!
you prob need a fake o2 sensor, ""dummy" whatever, its just going to happen, if you think they have fried it, pull it out and test it...... how do you test it? i have no idea but its prob. because of the new kit. have you tryed getting the code cleared? autozone, and advanced auto will do it for free.......... but dont let it go like that for long without fixing it.... you'll use up a **** ton of gas
Re: Help!!!
so if i got a dummy would i still be able to pass inspection?
Re: O2 Sensor question
ok so i got the code and its p0141 and it says that a malfunction exists in the heater circuit for oxygen sensor 2 in bank 1.
As said above, this is a code for the O2 sensor screwed into your cat
Check and make sure no wires were cut/damaged/pinched.
Reset the ECU and check to see if the code comes back.
If everything is good and the code comes back, you might need a new O2 sensor.
If you get an O2 sensor, go ahead and make sure it is a Denso brand. There are very few OBD-II hondas that like the Bosch replacements sold at most auto parts stores. I would check Majestic Honda's website for a good price.
ok so its not the one thats close to my oil pan? Its the one plugged into my cat? and how exactly do i reset my ecu?
You can pull the ECU fuse, or disconnect the battery (just make sure you have the radio code).
I would recommend pulling the fuse.
Ok i just looked for a sensor on majestic honda and i couldnt find one and are you talking about the security code for the radio
http://www.hondaautomotiveparts.com/...5=EXHAUST+PIPE
^Looks like #27
Yes, the security code for the radio.
^Looks like #27
^Looks like #27
^Looks like #27
alright thanks alot for all your help i really appreciate it.
After the cat?
Secondary O2 sensors on an EK EX are screwed into the cat itself...there are no sensors after the cat.
In the above diagram, #40 is the Primary O2 sensor, and #27 is the secondary sensor.
amej8
07-11-2006 06:25 PM
