axel broke....
axel broke....
ok i was pullin my axel out on the driver side and the axel broke and now its stuck in there the rest of the axel is out is there any other way to pry it out i tried everything please someone help ASAP
Re: axel broke....
a few good smacks with a hammer will loosen it up. a longer screw driver will pry it out then, your more than likely going to leek gear oil or trans fluid so have some on hand.
Re: axel broke....
well nevermind i had to take out the axle shaft cause i have an ls in the hatch and i still have to pull my tranny out in order to change my clutch lol cause the end of the axel is stuck in the axel shaft cause all my bushings fell out from the axle so yea its to cold for this **** im finna start headin outside in 4 hrs if anythin ya let me know any other solutions thanks alot
Re: axel broke....
it doesnt matter if the bushings fall out (i understand you mean the three bearings). a few good smacks with the hammer will loosten it up. them you will be able to pry it out with a screw driger, just remember, hit it with directionality proportional to the way it is supposed to some out.
Re: axel broke....
my ball joint separators all have the tines of the fork too close together to fit around the axle shaft but if yours is different it may work perfectly.
I did this to an axle once, and I got the end out by prying on it and cursing at it. I lined up all three of those bearings in the housing of the end and slid it all back together. it's been working fine for a while now, but all the grease ended up on the side of my motor...
Gynntonyx
06-05-2016 01:18 PM
ILLICON3000
03-03-2005 11:13 AM
07734
12-01-2004 06:51 PM
