Just got F&R sway bars. few Q's
So i just picked up a 19mm rear sway from the junkyard today off a 95 4dr. seems to be aftermarket. does anyone kno who the bar could be made by? The endlinks mount to the out side of the LCA with a bracket attached to the bolt, all others i have seen mount to the LCA its self. where could i find endlinks? also i got a sway bar off a si coupe, i think it is about a 21mm. how hard is it to install it?
Re: Just got F&R sway bars. few Q's
They mount to a bracket? Post some pics dude, that will really help. Pics are worth 1000 words.
To make the Si sway bar fit, youll need Si end links, LCA's, shock forks, brackets, and bushings. I dont know if it will fit an EG. Also, its a 25mm sway bar.
they're probably ST sway bars. Suspension Techniques. they're the only ones that come to mind that mount to a bracket outside of the normal sway bar link areas that come to mind.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/asr-brace-suspension-technique-sway-bar-2636748/ some sample pics of it installed on my car and another users car.
Those will work with your current LCA's They attach to the lower shock mount bolts. You need to get longer bolts though. And GL geting them out cleanly. Alot of times they are seized int eh LCA bushing and the heads break off.
You alos need to find/make some endlinks.
any ideas on where i could find the just endlinks? i am going to call st tomorrow. would front stock endlinks work? like this one http://www.modacar.com/bolt-on/produ...7817-4964.html
in that link 2 different size endlinks were used? how much did putting the rear bar on ur car help the handling?
you definitly feel the difference the only problem i still have is torn trialing arm bushing. i'm to lazy to change them right now tho considering its cold and i don't have a heated garage.
immajackuup
04-22-2009 12:25 PM
JMelt4
18
04-30-2007 07:43 PM
