removing stubborn b!tch pin?
Old 12-27-2009, 09:30 PM
Corksil's Avatar
Default removing stubborn b!tch pin?
hey I am trying to remove my shift linkage from the wehicle and I can't seem to get the b!tch pin out of the tranny-side shift linkage.
any tips?
I've tried using an allen lunch and beating the **** out of the b!tch pin but it wouldn't come out.
Old 12-27-2009, 09:33 PM
meandino's Avatar
Default Re: removing stubborn b!tch pin?
Use a punch, and a BFH.
Old 12-27-2009, 09:39 PM
FroMan's Avatar
I always use a 12mm bolt, specifically the one out of the IACV on the back of the intake manifold. works every time for me unless the bitch pin is messed up.
Old 12-27-2009, 09:48 PM
Corksil's Avatar
12mm bolt or punch and BFH. got it, will tackle that problem tomorrow.
Old 12-27-2009, 09:52 PM
martn53's Avatar
http://www.performanceforum.com/wesv...tch/bitch.html
Old 12-27-2009, 10:48 PM
thumper64's Avatar
there's a special punch for roll pins, it has a ball shaped thing on the end and it works amazing. Or if you have an air hammer, grind a pointed end down so that it will be narrow enough to push the pin out most of the way.
Roll pin punch:
http://www.gswagner.com/shoptools/rollpinpunches.jpg
If you get the pin all the way out, if you put a little more bevel on the pin using a file it's easier to tap it in with a hammer.
Old 12-27-2009, 10:52 PM
del sol noob's Avatar
i just took mine off and i used one of those small screw drivers they sell in a box set and my hammer hahah it came right out
Old 12-27-2009, 11:51 PM
Year 3030
Sumslapper's Avatar
good smack with a punch and its out
Old 12-28-2009, 06:36 AM
Oh look, I can change this
deschlong's Avatar
Good link.
Old 12-28-2009, 09:40 AM
miguel329's Avatar
extension and a 4mm socket works great 4 me, just whack it a few times
Old 12-29-2009, 10:09 PM
Corksil's Avatar
thanks for the linkz0rz honda tech.
I decided to drop the tranny with bitch-pin intact in all of it's bitchiness.
Old 12-29-2009, 10:10 PM
coco502's Avatar
you just got to keep smacking that b!tch pin
Old 12-29-2009, 10:14 PM
darkenedsol's Avatar
Be careful when using tools not made for it-you could either mess the pin up and have to replace it, or mess it up and get it really stuck. I actually bought a tool a while back a friend at a local Honda dealer told me about, and I absolutely love it. I can either use a BFH and knock it out, or it chucks into my air hammer to blast it out-no sweat. The problem with using a punch is you can damage the edges or expand it to stick it worse. The tool is made by Schley Products and has the part number 65650 on it. Runs about $20 and worth every penny. Hope this helps!!!!
speedjunkie_g35
29
08-20-2023 09:42 AM
spens 91 Ef
19
01-08-2009 07:14 PM
redboost10
07-22-2007 06:58 AM
sosleepy
03-16-2006 06:25 AM
DesiDez
07-03-2003 08:31 AM
Quick Reply: removing stubborn b!tch pin?
