Help 1995 civic depressurze fuel?????
Hi im wanting to change out an old fuel filter of mines and will add a fuel gauge on the banjo bolt,
First of all how do you depressurize the fuel pressure the book says to take out a fuel pump fuse after running the engine and shut off I can't find the fuel pump fuse.
also remove the fuel cap???
how??? pls help..
Also i bought a fuel filter from Napa but i didn't install yet because the bottom bolt is longer than factory bolt. will the fitting fit i dont want to remove yet???
how??? pls help..
Re: Help 1995 civic depressurze fuel?????
honestly the easiest way is to take off fuel cap and just use rags over the fuel filter while removing the banjo bolt. thats how i do it at worK. the system really not under that much pressure.
Master23
06-23-2009 05:23 PM
