LS swap issues/air fuel
Old 03-04-2010, 05:38 AM
zGo
zGo's Avatar
Default LS swap issues/air fuel
Just picked up an OBD1 swapped 92 eg sedan. It has an Autometer wideband that I believe may be hooked up to a stock O2 sensor. The wideband reads all the way 'lean' the guy told me it runs 'rich' either way its a rough start up but after that it idles fine, when you're driving it's obvious there's something going on.
Would tying the wideband/gauge into the stock O2 cause it to run like this or is this maybe an injector/fpr issue?
zGo is offline
Old 03-04-2010, 05:48 AM
I'm not Rick!
rick_rabies's Avatar
Default Re: LS swap issues/air fuel
your gauge has nothing to do with it. but you do need to have the correct oem narrow band o2 sensor plugged into the engine harnss.
check your plugs. replace them.
and check fuel pressure.
any CELs?
rick_rabies is offline
Old 03-04-2010, 06:50 AM
Matt93eg's Avatar
any CELs?
To add to that, what ECU are you running? Is the ECU Chipped? You should be running an OBD1 P75 ECU.
Matt93eg is offline
Old 03-04-2010, 08:43 AM
Civicfanatic_09's Avatar
Are you sure it isn't one of those cheap Autozone A/F guages, because they don't do anything but light up colorful lights.
Civicfanatic_09 is offline
slammedz6ef
02-08-2008 10:07 PM
97grnrs
03-08-2006 09:47 PM
RemerLex11
08-16-2004 09:58 AM
swlabhot
01-20-2003 06:50 AM
MugenPoweredLude
12-29-2002 12:18 AM
Quick Reply: LS swap issues/air fuel
  • Ask a Question
Question Title:
Description:
