Ek Passanger side trans mount help
I have purchased a civic with a hacked up motor swap. Its a 98 ek coupe. So i am doing an ls swap with gsr trans for a little extra dd power.
The tab on the passanger side framerail (where the trans mounts bolts to)is missing. the trans mount is currently welded to the frame, it looks like crap! What is the best way to fix this when i swap the ls motor in? my car was an auto, one of the previous owners did the manual swap.
is there a better bracket i can use? such as the bracket on an integra or something?!
Re: Ek Passanger side trans mount help
wow. Its a legit question.. you can use the engine bracket on the driver side from the integra because its stronger when you do b swaps into ek's.. mabye there was a chance of using the passanger trans mount. ive search, not much to be found in relation to my specific question.
Hondaruss
16
10-14-2010 04:28 PM
