Replacing Amber Bulbs On My EG6 SiR Cluster HELP!
Re: Replacing Amber Bulbs On My EG6 SiR Cluster HELP!
Take off your cluster benzel first. You'll have to take the clock off to get the benzel off. After that there is a couple mounting screws for the cluster. Take those off. Then unplug the cluster. Once you have it out, there are these little round connectors on the back that just turn and come out. Take out the three bigger ones and the bulb will be in the connector. If all the bulbs went out at once, then check your fuses under the dash first.
All the oem blulbs are white with like blue condoms on them making them whiter. Just get these bulbs. Can find em at autozone or anywhere.
Oh look, I can change this
Wait a minute -- all your bulbs are out? If they all went bad at the same time, you have a different problem than just burnt out bulbs. It might be a fuse, it might be a bad ground ... but probably not all burnt out at once.
also
Search:
Keyword(s): DIY cluster lights
Forum: Honda Civic/Del Sol (1992 - 2000)
Search took 0.16 seconds
all info on how to remove cluster, change bulbs, where to buy the bulbs are all there.
