2000 si Overheating ISSUE HELP ASAP!!!
Old 03-04-2010, 07:12 PM
Neo218's Avatar
Default 2000 si Overheating ISSUE HELP ASAP!!!
Ok buddy has a 2000 si and its still overheating after replacing waterpump and thermostat. Fan still works and holds collant untill it overheats then it comes out of the overflow tank anyone have any idea what could be the prob?
Old 03-04-2010, 07:28 PM
D16SiHatch's Avatar
Default Re: 2000 si Overheating ISSUE HELP ASAP!!!
assuming you've bled the air out for an adequate period of time, i'd lean toward thinking its a blown headgasket.
Old 03-04-2010, 07:31 PM
langjairicer's Avatar
Yeah did you try bleeding the coolant system?
Old 03-04-2010, 07:34 PM
MiG-21 superfan
builthatch's Avatar
compression leaking into the coolant jacket, therefore over-pressurizing the cooling system, triggering the rad cap, which in turn will make it regurgitate coolant indefinitely through the overflow...
Old 03-04-2010, 08:28 PM
Former User's Avatar
A blown head gasket is a real possibility. But first replace the radiator cap and bleed the cooling system. During the bleeding procedure, regularly check whether the lower radiator hose remains cool even after the engine is hot. If so, the radiator may be clogged.
Old 03-05-2010, 09:01 AM
Neo218's Avatar
Ok how do you bleed the cooling system?
Old 03-05-2010, 09:05 AM
jayWknight's Avatar
I would opt for a leakdown test.
Old 03-05-2010, 10:23 AM
xlee08's Avatar
This happened to me before, it was my radiator at the time. yours may be different.
Old 03-05-2010, 08:24 PM
Neo218's Avatar
How do you do a leakdown test?
Old 03-05-2010, 08:36 PM
hondaPOWERD's Avatar
you need a coolant pressure tester which is a pump that connects to your rad. then you put the system under pressure about 15 psi
Old 03-05-2010, 09:01 PM
doritosFTW's Avatar
Have you tried putting a bag of ice on top of the valve cover to help cool the engine down?
Old 03-05-2010, 09:51 PM
iamthefollower's Avatar
Not another one...
I'm thinking the radiator could be clogged, check the cap and bleed the cooling system as everyone has stated and check all that before having to pull the head off.
Old 03-05-2010, 10:18 PM
spoon_concept_eg6's Avatar
if the ride aint puffing a white smoke screen, spend 100 bucks and buy a aluminum radiator of ebay or something. that radiator is probably clogged. check spark plugs, they shouldn't be burning white, or be wet. common trouble shoot for these problems, black smoke=burning rich(gas), white smoke=burning water, gray=burning oil. end of story.
Old 03-05-2010, 10:23 PM
Originally Posted by drifter188
Have you had any experience with ebay radiators? Just trying to find out if they're any good
I have, they work good. A buddy of mine had one on his car.
Old 03-05-2010, 10:26 PM
i put one on my buddies car. solved all the over heating problems. same if not better than stock.
Old 03-05-2010, 11:04 PM
BiG ChOr!Zo's Avatar
ROFL
Old 03-06-2010, 08:08 PM
D16SiHatch's Avatar
ehh, not so much
http://www.carcraft.com/techarticles...ter/index.html
Old 03-06-2010, 08:11 PM
b1u3_5i's Avatar
x2
Old 03-06-2010, 08:16 PM
This procedure may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below
accel
04-10-2013 07:54 PM
runwitme
14
05-17-2009 04:16 PM
jaywoodz
11-09-2008 08:02 PM
Gvis420
10-20-2007 02:37 PM
Quick Reply: 2000 si Overheating ISSUE HELP ASAP!!!
