inconsistant idle
inconsistant idle
I have searched the forums and have been unable to find what Im looking for. My car is a 93 Del Sol SI, D16Z6. The problem is sometimes it idles normal at about 650 rpm, other times I have to pump the gas to get it to start and it will idle at about 1600 rpm. When the idle is high, when I first hit the gas it feels like its choking out and wants to die. Ive only had this problem for about a week now, wondering what it could be and where to start. No check engine light comes on at all either. Any help is appreciated, thanks.
Re: inconsistant idle
yes, stock ecu. The only parts on the motor that are after market is the underdrive main pulley and the intake. both of which have been on the car for over two years with no problems
Mine's the opposite after a long drive and its all warmed up the idle goes down too much. Like as low as 400rpm but it doesn't die out...just shakes a bit. Motor is a b16a2 eg6 that I just bought.
Going to change plugs and wires tomorrow, oil and filter changed about 600 miles ago. How often should you replace fuel filter? have had the car for 4 years and it has not been replaced
Your fuel doesnt really have any problems if it is stock, i like to change mine every time i do the timing belt, so like ninety thousand miles. Once the car is older than six or seven years i do it every year because of rust debris, dirt, grime anything that might build up over the years. That's just preventative maintenance. When i change it has always been pretty clean. I would change it and then just see how the fuel looks in the old one and if its pretty bad change it every year.
