my car gets no spark and no fuel injection firing
my car tries to turn over but theres no spark and the fuel injectors arent firing ive checked everything twice im just pissed
Re: my car gets no spark and no fuel injection firing (spoonspeed)
my ecu worked before so im pretty sure its not that ill check the main relay but we checked the fusebox under the hood and all the fuses came up as good ill recheck them though i am getting a scan tool tomorrow hopeully ill have answers then wheres the main rlay at im a novice
Re: my car gets no spark and no fuel injection firing (W C L)
there was 2 grounds on the old engine one on the head that goes to the frame on the driver side front side of the head and then one coming off the tranny that bolts to the frame on the passenger side of car under hood
having the same problem on my crx, except i hear a ticking noise coming from my eacv when i put the key in the ignition and turn it to acc. also i just put in a new dizzy but still no spark.....however i have power to the coil. any idea whats wrong?
Re: (avirex_man_2000)
got fuel in the tank?
check fuel pump to see if it working by turn the ingition key on
check for ground.
what motor is in yoiur car?
need more info
check for ground.
need more info
Re: (m3dia_lab)
doesnt explain the lack of fuel though...interesting, i had the same **** go on with my car, it still does it everyonce in a while, like its flooded...but obviously FI cars shouldnt flood.
