'94 civic with Integ computer...check this out
I have a B20/vtec motor and it has what seems to be ecu problems. I was at first throwing random codes now its more consistent. I throw 9 (CYP...#1 cylinder postion I believe) and # 17 which is VSS (I just need a new one). What usually makes the code 9 pop up. The book I have isn't really clear and this is a problem I have never encountered before. Any help would be appreciated. All flames welcome...cuz I can't avoid them.
Re: '94 civic with Integ computer...check this out (D-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-t »</TD></TR><TR><TD CLASS="quote"> ^^Oops missed that. I thought he wanted to put in an Integ ECU. </TD></TR></TABLE>
Nah, I just know because I talk to him on the regular.
Re: '94 civic with Integ computer...check this out (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Nah, I just know because I talk to him on the regular. </TD></TR></TABLE>
Yeah...we tizzite like that. "Chad" said the code 9 can be a bad ignitor...but in the Honda manual (which I do not have at the moment) I think it has something to do with the distributor and Top Dead Center.
EDIT: And to TeamNextGenChris....the download will take 10 hrs
Alrighty....what is the CYP and what does it look like and is it removable as a single unit?
Re: '94 civic with Integ computer...check this out (GTlvr82)
CYP = cylinder sensor. You most likely need to get a new one of course.It is pretty bad to drive on distributor codes. You should go to junkyard first because Honda will make you buy a whole distributor sub-assembly, you can't just buy the CYP sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-t »</TD></TR><TR><TD CLASS="quote"> CYP = cylinder sensor. You most likely need to get a new one of course.It is pretty bad to drive on distributor codes. You should go to junkyard first because Honda will make you buy a whole distributor sub-assembly, you can't just buy the CYP sensor.
Yeah...and its really hard to find a OBD2 GSR just chilling in a junkyard...but I have a few sources.
EDIT: The dizzy is a OBD2 piece...not OBD1...it is run by a obd1 computer and the wiring is correct. Tom helped me with that.
