HELP!!! My window is fu#@ed!!! And its COLD!!
Old 01-14-2004, 08:30 AM
Matt B's Avatar
Default HELP!!! My window is fu#@ed!!! And its COLD!!
I put the power window down to get food at the drive through and now it will only go up half way. Its -3 degrees outside!!! It looks like it fell off the track because it stops going up when it hits the rubber by the side view mirror. Is there anyway to fix this without taking the door apart? Thanks.
Old 01-14-2004, 08:33 AM
Ricey McRicerton's Avatar
Default Re: HELP!!! My window is fu#@ed!!! And its COLD!! (Matt B)
Nope..gotta pull the door apart and set it back on the track. Mine used to do this all the time. Go get some silicone spray and lube that track up good!
EDIT: To get the window to go up as a tempororary fix loosen up your mirror and roll the window up anyway. The window is getting stopped by the mirror, so just losten it up for the time being..that will keep most of the wind off of you. My car went through a tornado like this and it kept most all of the water out.
Old 01-14-2004, 08:37 AM
egizzle8
Guest
Posts: n/a
Default Re: HELP!!! My window is fu#@ed!!! And its COLD!! (Ricey McRicerton)
-3 and your in TX. Good lord I didn't think it got that cold down there. Go get some static clip wrap and you can just pull a sheet down when you need a new window. MaD ghetto though. Sorry homie
Old 01-14-2004, 08:39 AM
BlackNoise's Avatar
Default Re: HELP!!! My window is fu#@ed!!! And its COLD!! (egizzle6)
hey! i was at the drive through and my window fell into my door!! we are twins! i took mine to honda and they said it would be 350 bucks to fix...i said **** you
Old 01-14-2004, 08:40 AM
Default Re: HELP!!! My window is fu#@ed!!! And its COLD!! (BlackNoise)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackNoise &raquo;</TD></TR><TR><TD CLASS="quote">hey! i was at the drive through and my window fell into my door!! we are twins! i took mine to honda and they said it would be 350 bucks to fix...i said **** you
350 to fix it!! Holy crap!! I can get my door apart, fix the window and have it back together in under 20 minutes!! They've got to be kidding!!
Old 01-14-2004, 08:42 AM
The Internet Tough Guy's Avatar
holy ****. the same exact thing happend to me. at the drive through, put window up.. didn't go up. wierd.. why the hell did this happen?
here's how you fix it (for a 6th gen.. 5th gen may differ slightly). remove interior crap: 3 screws underneath speaker grill that pops off. 1 screw behind door handle. 1 screw inside armrest pocket thingy. pop that off. loosen the gold 10mm bolt down where the speaker is. slide window back, slide track onto window and bolt everything back up. easy fix
Old 01-14-2004, 08:44 AM
Default Re: HELP!!! My window is fu#@ed!!! And its COLD!! (jwn7)
^^ Yep. Don't forget to lube the track though!! I really thought something in my whole setup was bent/broken until I lubed it up. This ended all of my problems in a $2.50 can of silicone lube!!
Old 01-14-2004, 08:46 AM
KiDSoL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">^^ Yep. Don't forget to lube the track though!! I really thought something in my whole setup was bent/broken until I lubed it up. This ended all of my problems in a $2.50 can of silicone lube!! </TD></TR></TABLE>
Same thing happened to my sol and to my girls 97 ex.
you dont have to take much off the door take your maybe like 20 mins. Where the hell in TX you live for it being that cold? its like 60 degrees here...
Old 01-14-2004, 08:49 AM
Matt B's Avatar
Thanks for the replies. I'm not in texas, i just put that to throw off the theives. I don't have any tools here at work so i guess i'm fucked until i get home. Damn. I'm gonna freeze my ***** off.
Old 01-14-2004, 08:50 AM
Banned
98 Ek LsVtec's Avatar
sorry guy but you have to take off the panel
laoboisosilly
06-03-2009 02:14 PM
MiracleWhip
12-20-2007 04:49 PM
Agent Zero
08-13-2004 01:53 PM
EX-T
11-27-2003 07:26 AM
io_burn
10-14-2001 08:27 PM
Quick Reply: HELP!!! My window is fu#@ed!!! And its COLD!!
