Exhaust Manifold Gasket Q - Help
Hello, I'am installing 4-1 dc header on my JDM SirII B16 in my 2000 Honda Civic Si, I am going to change the gasket (Ex. Manifold Gasket? I think thats what its called) and the bolts. My question is, do I have to apply anything on the gasket or bolts? What setting should I torque the bolts @? Thanks
Re: Exhaust Manifold Gasket Q - Help (SiRacer365)
I never put anything on the gasket to prep it....i know i might catch heat for this but i just finger tightened them and then put a alittle pressure on the nuts with a ratchet
you should apply anit-seize on teh bolts. you dont need to put any sort of dressing on the gasket, just make sure both surfaces are clean. i dont kno on the top of my head what the torque on the nuts are, but dont torque them down too tight. i hear of ppl breaking them all too often
Solbros Owns Me
Re: Exhaust Manifold Gasket Q - Help (95excoupeMT)
Why change it???
It's metal and if it's not bad, just re use it. And why new bolts??? Just torque to specs and you're fine
Re: Exhaust Manifold Gasket Q - Help (Emerika)
Im just changing it for the hell of it. Last time I changed my header .. I broke off some bolts, so I had to buy new ones. I just want to change everything I guess. Does anyone know stock specs for the bolts?
O.. another Q...where can I get this anti-seize stuff?
Modified by SiRacer365 at 11:07 PM 1/15/2004
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRacer365 »</TD></TR><TR><TD CLASS="quote">
O.. another Q...where can I get this anti-seize stuff?</TD></TR></TABLE>
Pep boys...anti seize lubricant
And I do agree with emerika...why change it if its metal and nothings wrong?
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRacer365 »</TD></TR><TR><TD CLASS="quote">What setting should I torque the bolts @? </TD></TR></TABLE>
23 ft-lbs.
23 ft-lbs.
rewerbcrx
12-15-2005 06:23 PM
