Used pistons - Hone the block or not?
If I'm putting used P30 pistons (nearly new) in a used B18c block (also nearly new) is it nessecery to hone the block if it looks good?
Re: Used pistons - Hone the block or not? (Robban26)
Make sure the block is square on top and that the sleeves are round...and try to match the pistons/rings to the hone job so that you have proper clearance...but not too much. All you haters....correct me if I am wrong.
Guest
Posts: n/a
if you have new rings, then yes you should hone. if you are reusing the old rings (ghetto) you may as well run it as it is since you're just hoping that the rings will seal in exactly the same way as they in the last engine.
during break in the cross hatch from the hone wears the rings to the shape of the cylinder so they seal, the shape of the worn (used) rings may not be the same as your worn cylinders, if it's off by too much you'll get a bunch of blow by.
Re: Used pistons - Hone the block or not? (thad)
That's also what I figured so honing the block it is! The thing that sucks is that I don't find any new P30 pistons in Hong Kong were my friend lives. I think that's odd.
So if i take the used pistons with new rings and hone the block, that will be ok?
It's not the pistons that are worn out or is it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Robban26 »</TD></TR><TR><TD CLASS="quote">So if i take the used pistons with new rings and hone the block, that will be ok?
It's not the pistons that are worn out or is it? </TD></TR></TABLE>
New rings and a hone job is a must. If the cylinders are worn (measure the roundness), then you may not only need to hone them but bore them as well. Likely they will be fine..
The pistons shouldn't be worn. But always inspect them. If they've been slapping against the cylinder walls in some other engine, there should be evidence uncovered by closely measuring them.
Re: Used pistons - Hone the block or not? (Nameless EJ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless EJ6 »</TD></TR><TR><TD CLASS="quote">
The pistons shouldn't be worn. But always inspect them. If they've been slapping against the cylinder walls in some other engine, there should be evidence uncovered by closely measuring them.</TD></TR></TABLE>
again nameless is on the money. man this guy is good
Risky Business
Re: (stock93cx)
I wouldnt use used pistons at all. Pistons as well as cylinder walls are wear items...over time they both become egg shaped instead of circular shaped. So if you put old pistons in an old block, you're putting one egg inside of a different sized egg. If you hone the block, your'e putting an egg inside of a circle...just get new .25 overbore pistons and have the block bored and honed to match.
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">I wouldnt use used pistons at all. Pistons as well as cylinder walls are wear items...over time they both become egg shaped instead of circular shaped. So if you put old pistons in an old block, you're putting one egg inside of a different sized egg. If you hone the block, your'e putting an egg inside of a circle...just get new .25 overbore pistons and have the block bored and honed to match.</TD></TR></TABLE>
I never even thought of that.....damn. I am gonna remember that when i do my build.
Risky Business
Re: (GTlvr82)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTlvr82 »</TD></TR><TR><TD CLASS="quote">
I never even thought of that.....damn. I am gonna remember that when i do my build.</TD></TR></TABLE>
Yeah my friend didn't either and he had to rebuild his LSVTEC at 10,000 miles because he was burning a quart a week
Re: (BauleyCivic)
Like others said, u mast check if they are truly round or not, use a micrometer and measure the thrust side to back side and measure right above and below the wrist pin. Same thing with cylinder bores.
Re: (leadfoot78)
I'm going to measure everything just to be on the safe side. If I notice that someting isn't right then I'm buying new pistons and bore the block.
Re: (92civeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civeg »</TD></TR><TR><TD CLASS="quote">is it true that if you hone a block you need to reglaze it also?</TD></TR></TABLE>
wait, i could've sworn the purpose of honing was to remove the glaze
Re: (92civeg)
NO and i never heard of that before
Ryhaz
10
01-14-2014 07:57 AM
vtec.dc2
09-28-2003 12:19 PM
KC GSR
06-20-2002 08:47 AM
