Piston to deck height? Please help..
Piston-to-Deck Height
OEM B16A/B
OEM B18A/B/C1/C5 - B20B/Z
Other
On this page: http://www.c-speedracing.com/h...c.php
You can calculate the compression on different blocks etc.
But what piston to deck height am ís correct if I use B18c block, B16a head?
OEM B16A/B
Other
Re: Piston to deck height? Please help.. (Robban26)
Piston to deck height, is bascly when the piston is at TDC, it doesnt stick above or below the top of the block. This can mostly be affected by rod lenght unless you are usng custom pistons which are shorter or what not.
This is what i understand and is why i dont really understand your question. My answer would be, yes, it has a perfect piston to deck height.
Somebody correct me if im wrong.
Re: Piston to deck height? Please help.. (allmtr)
I mean that if I have a B18c block and a B16a head. Wich piston to deck height is it?
Is it 0.020 or 0.030?
OEM B16A/B - 0.020
OEM B18A/B/C1/C5 - B20B/Z - 0.030
Other
OEM B16A/B - 0.020
Other
