Stock tach not working after swap
Already did search. I just finished a 99 b18c1 swap (99 wire harness, p28 ecu) in my 93 si and the tach isn't working? Can some1 point me in the right direction?
Re: Stock tach not working after swap (cvrboi)
did you double check your speedo sensor? its on top of tranny in case u didnt know. make sure everything is intact and working properly
Rob0
Rob0
did you use obd2 harness?? if you did you will need to run 1 wire from driverside shock tower harness to distributor.
Rich Pedraza Jr
07-30-2009 06:18 AM
Tyson
40
06-04-2009 04:24 PM
