d15b7 engine timing
Old 01-15-2004, 06:56 AM
93coupeDX's Avatar
Default d15b7 engine timing
ok....can someone tell me if I'm right or wrong on this. When you are putting a new timing belt on a d15b7 engine you line the cam pulley marks flat with the head and line up the crank pulley with the center mark on the crank pulley to the mark on the cover or do you use one of the other marks on the crank pulley? My crank pulley has three marks on it, what are they all for?
Old 01-15-2004, 07:36 AM
Risky Business
BauleyCivic's Avatar
Default Re: d15b7 engine timing (greenjunk)
Old 05-04-2004, 12:25 PM
iNetForce's Avatar
Default Re: d15b7 engine timing (BauleyCivic)
that picture shows how to line up the groove with the oil pump, but what about lining up the pulley? I'm not changing my timing belt, im redoing the timing, what do i line up on the pulley? which mark>? line up to what?
Old 05-04-2004, 12:45 PM
speedfreek128's Avatar
put a socket on the crank pulley bolt and turn it until the single mark( seperate from the three in a group) on the pulley is lined up with the pointer on the bottom cover....that is tdc for cyl #1.....then turn the cam until aligned with the head like in the above pic.....put belt on and tighten until there is about half inch of play......start engine and let idle till fan comes on...check timing with light....pointer on cover should point to center mark....if not turn dist left or right until it is
foolsforever
11
08-09-2018 05:08 PM
dfabulous
10
12-09-2007 11:00 PM
90jdmcrxdude
05-13-2006 04:43 AM
90jdmcrxdude
05-12-2006 09:02 PM
Ryan C
03-25-2004 06:30 AM
Quick Reply: d15b7 engine timing
