help civic b16
help civic b16
i have a civic hatch 93 with a b16. my car seems to stall. it doesnt turn of mut it kind of bogs. it flashes a code. manifold pressure sensor(ithink, im not positive if the first flash is an indicator) if it is an indicator that i believe the code represents ox sensor 2. witch one is it. and what is it help. thank new
1 Post
Re: help civic b16 (chulopilong)
first you need to figure out exactly which code you have before we can help you.use the search function to find out how to properly read the codes on your car.
chris
chris
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chulopilong »</TD></TR><TR><TD CLASS="quote">it code 3 manifold absolute pressure sensor.
a MAP problem can definately cause the symptoms you're speaking of...go here
http://www.icelord.net/honda/repair/and DL the 92-95 manual(same procedure for the B16)and do the troubleshooting procedure for the MAP sensor circuit.if you need help,let me know.
chris
chris
