BLOW OFF VALVES...???
Re: BLOW OFF VALVES...??? (BooSTED IsLANDER)
teh flange side goes to your intake piping after the turbo and IC. The nipple that is provided goes to a vac source on the intake. what BOV are you talkign about anyway?
Re: BLOW OFF VALVES...??? (jdmdelsol)
what vacume source are you talking about, i tried that but still does not work, i placed the spring on soft and still does not work, vaccume on where? intake or intake manifold???? thanks
This user can set his title.
Re: BLOW OFF VALVES...??? (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">are you taking the guy serious?
I don't think so.
I don't think so.
also, would the welding make a difference? for example if i cut a hole in the charge pipe and stuck the flange a little lower than the charge pipe surface, will that make a difference? thanks for the reply....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">You have to drill a hole in your exhaust manifold, and tap in a male nipple, and run the hose to that. </TD></TR></TABLE>
That's a good way of helping somebody out
Re: BLOW OFF VALVES...??? (5thgencivic)
I placed mine before the throttle body but after the intercooler. Run a T off of your brake booster line (between the intake mani and the check valve). Find me a picture and I'll show you where to put it all. With that said, when I put mine it it was a TiAL and it was stuck shut. I put it on a vaccum pump and had to pump it to almost 120 cm/hg3 before it came open.
Attoir
05-21-2006 06:36 PM
