Rear Disc EX
Rear Disc EX
I just swaped my 97 civic ex to rear disc but the e-brake cables dont work, so i thought about trying the ones off the car that i took the rear disc off and still no go. I took the rear disc off a 94 del sol, so i am out of option and no part store around here has NO CLUE WHAT THE HELL THEY ARE DOING. So if anyone has any ideas i could use the help!!!!!!!!!!
Re: Rear Disc EX (JV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV »</TD></TR><TR><TD CLASS="quote">99-00 Civic SI cables</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JV »</TD></TR><TR><TD CLASS="quote">99-00 Civic SI cables?</TD></TR></TABLE>
I'd go with these because they were made for the exact dimension of your car. These are what I use on my EX with rear disks.
Re: Rear Disc EX (VtecDeMoN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecDeMoN »</TD></TR><TR><TD CLASS="quote">99-00 Si or 94+ Integra...
Brian</TD></TR></TABLE>
Yes, use these. I did my conversion from a del sol and the e brake cables were too short. That is because del sols have their own layout. The hang from right under the chassis suspended by the bracket, were as the civics and integras brackets are secured inside the car. You can just swap the cables out.
Re: Rear Disc EX (rsxts2003)
I did rear disc out of a 92-95 Civic HB Si onto my 94 Civic EX 2dr, and the ebrake also hardly works. The cable is secured tho under the car. Is that my problem also? Need to use 94-01 Integra cable or 95 Civic EX cable?
Re: Rear Disc EX (e1even)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e1even »</TD></TR><TR><TD CLASS="quote">I did rear disc out of a 92-95 Civic HB Si onto my 94 Civic EX 2dr, and the ebrake also hardly works. The cable is secured tho under the car. Is that my problem also? Need to use 94-01 Integra cable or 95 Civic EX cable?</TD></TR></TABLE>94-01 Integra cables. 95 Civic EX did not come with rear discs. I don't know if you'll be able to use 92-95 Si ebrake cables though? HTH.
Brian
Brian
92-95 Civic EX Coupes had option for ABS/rear discs
92-95 Civic EX Sedans had standard ABS/rear discs
92-95 Civic LX Sedans had option for ABS/rear discs
92-95 Civic Si Hatch... I can't remember if it was standard or option
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e1even »</TD></TR><TR><TD CLASS="quote">It was off a EG HB Si. They are the proper brake lines for that car. Why am I even wasting my time replying to you lol?</TD></TR></TABLE>
Good question, no foul then... Play ball!
sweet you guy kick ***, i go the cables for a 99 si and they work perfect. Thanks again, because i dont know anything more annoying than no ebrake but that might just be me.
swifty4u
18
09-15-2005 02:42 PM
eK9aT10pSi
71
02-07-2005 12:25 AM
