pulling axle from midshaft, searched for 20 minutes
Go Tigers!
does anyone know how to pull axle from the midshaft? I've been trying for the past hour and a half with no luck.
Re: pulling axle from midshaft, searched for 20 minutes (bense)
you need a fat azz flat head heavy duty screw driver... pop it between the axel and half shaft and that should do the trick...
Mr. Badwrench
i use a hammer and a prybar. line up the prybar on the inner joint. then hit it really hard and the axle will "walk" out. h.t.h.
Re: pulling axle from midshaft, searched for 20 minutes (boostedcivicsir)
Re: pulling axle from midshaft, searched for 20 minutes (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=382416</TD></TR></TABLE>
Go Tigers!
Re: pulling axle from midshaft, searched for 20 minutes (VWkila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VWkila »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
i read that, and it says nothing about the midshaft.....it deals with they passener axle.
Get a large socket, 32mm or something larger. Put it into where the Axel connects to the halfshaft, and hit it with a hammer.
It should seperate the two, my friend found this here on HT last year. DOnt know the exact thread but it worked like a charm. 5 wacks and we were done.
Re: pulling axle from midshaft, searched for 20 minutes (Moe)
pops out almost the same way as the passenger side does... get a pry bar inbetween the end of the axle and where it connects to the intermidiate shaft an pry it out... it will pop right out
Deano_D aka "Brick Top"
18
12-11-2007 02:49 PM
madmanmulligan
10
08-25-2006 03:35 PM
