Dynoed my car, i dont think the result is good (pic)
Ok here is the deal, now im not sure if my stock Civic EX(99) exhaust piping is killing it or what, but this is weird
Dynoed with
97 B18C1
P28 OBD1 chipped with OEM ITR proggy
Skunk2 IM
ITR cams
ITR pistons
ITR valvetrain
AEM CAI (3")
The rest is stock
The guy said im running too rich and need to advance my timming
Any ideas? Can exhuast really kill so much power, i mean stock GSR could probably output more?
I did compression test too before i went to the dyno, and it did 250 all four( NO IDEA what it is so high, even the techs @ honda were suprised)
Im doing Hondata as soon as my JDM DC header comes in ( Back ordered) with Toda cam gears, Greddy EVO 2 70 mm pipin,g 2,5 inch cat, AEM FPR and AEM Fuel Rail...........
I hope it will perform better
Dynoed with
97 B18C1
Skunk2 IM
ITR cams
ITR pistons
ITR valvetrain
AEM CAI (3")
The rest is stock
Re: Dynoed my car, i dont think the result is good (Denis Si)
Could be, a small exhaust is basicly like asking you to take a big break and then telling you to exhale thro a straw after you been running around. Its just not gonna work to well, Get a bigger exhaust
Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">looks its a true stunna!
# look bad man
# look bad man
big strong guy
Re: (Denis Si)
Im sure you Used .25 OS pistons and re-bored/honed your block? Along with new Bearings, etc....
If your going to rebuild your engine, Do it right the first time or pay for it later!
And honestly Those numbers are not really too too bad....Just figure a stock ITR would only make a little more power, and thats basically what you have now, other then the fact your head is not as good!
Try getting larger exhaust/no cat, etc... You will gain more power!
Eric
Eric
Re: (rainmanEK)
Well as i mentioned be4 i got everything ready except Header is back ordered
Its just i thought itll put out more, thats all
Can wait till i get Hondata ad tune this sucker
Re: (Denis Si)
Those numbers ******* blow dude. I hit a 153whp with my STOCK GSR in my civic (all it had was a cheap *** CAI, 4-1header, and 2.25 exhaust)
Get that exhaust opened up and youll see a difference im sure, but something isnt right with those numbers. Was this a tune or just a base dyno?
Re: (rainmanEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainmanEK »</TD></TR><TR><TD CLASS="quote">a stock ITR would only make a little more power</TD></TR></TABLE>
I made 147whp with an I/H/C/E B16A2, lower torque of course (106.9) but still, higher peak horsepower. Not trying to disagree just providing some info
Denis Si: Post your A/F chart if you have it.
If i were you i would def get a nice header, 2.5 inch exhaust, new spark plugs if they're old, bigger injectors, get that GSR fuel pump along w/ that motor, and HONDATA....ASAP!!!
Get that timing fixed too. Maybe it's way off???
This should take care of it hopefully.
Re: (Quad-Damge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge »</TD></TR><TR><TD CLASS="quote">check the comp on the motor make sure it's still good
those are like i/h b16a2 numbers
does ur block say b16a2 on it LOL </TD></TR></TABLE>That's bone stock B16a numbers
Re: (rainmanEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainmanEK »</TD></TR><TR><TD CLASS="quote">Im sure you Used .25 OS pistons and re-bored/honed your block? Along with new Bearings, etc....
Eric </TD></TR></TABLE>
my stock itr made 175 125
yes your stock EX exhaust is choking you. i dont know how much bigger an ex exhaust is compared to a LX/Dx/Vx exhaust, but im sure it cant be much bigger. i saw a stock GSR dyno with lower numbers than you have. 132 with the LX/Dx/Vx exhaust. then the apexi n1 brought it up to 153. get an aftermarket exhaust, and you will gain 20 or more whp for sure.
big strong guy
Re: (Brian.w.an.i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brian.w.an.i »</TD></TR><TR><TD CLASS="quote">
my stock itr made 175 125</TD></TR></TABLE>
Good for you...
I have seen with my Own Eyes Some ITRs Dyno Mid 150s!
Eric
Good for you...
Eric
Re: (rainmanEK)
im not bragging. im saying his engine did not put out a properly built itr's output. not even close
to add to this. ive seen a stock itr put 183 with a header, exhaust, fpr, and a comptech cai. he also had the front bumper removed, so that may have added 1-2 hp
