HEY....can you do like ol' V8er's and weld spider gears RATHER than LSD???
is there an equivilant to "welding spider gears" like the old GM cars rear ends?
can you do the same or similar method to your honda tranny???
Re: HEY....can you do like ol' V8er's and weld spider gears RATHER than LSD??? (z6)
Yeah I've heard about it being done. It's not a very good method but I heard it worked. I also don't believe it's legal for racing.
Mr. Badwrench
the bad thing is, if you do that, you will destroy your diff on turns. the idea of a differential, is to allow the inside wheel to turn slower than the outside wheel on turns. if you weld the spiders, or even do a prodrive spool, or equivalent, it is for track racing only.
1 Post
Re: (z6)
yes you can do it. good luck tho heh..
"the idea of a differential, is to allow the inside wheel to turn slower than the outside wheel on turns."
That is call an open diff
