help i have 3 codes throwing at me... i need help to fix them...
right now i have
10 IAT - intake air temperature sensor
14 IAC (EACV) - idle air control valve
21 VTEC spool solenoid valve
I don't know how to fix any of them... maybe i need to switch them around? or get new ones? or what? yes i have searched, didnt find anything that helped....
Re: help i have 3 codes throwing at me... i need help to fix them... (al3e)
code 10 is sensor on air inlet tube black.code 14 is sensor on manifold. code 21 is vtec its on the side of head green plug check connection and sensor
Re: help i have 3 codes throwing at me... i need help to fix them... (julio1998)
holy hell! thank you! i knew that...thanks tho..
i need to find out how to fix them....
have you tired switching the iac and the iat around? you could have them backwards. as far as the vtec solenoid you can take a wire and hook it to your battery and then touch it to the wire that comes from the solenoid itself and see if clicks or not. if it does then it is good if not then it is burnt up.
why are you throwing the codes? u just do a motor swap? need more info.. what ecu, what motor? things like this..
y-49
06-23-2007 05:05 PM
beedoublejay
08-21-2005 03:28 PM
Red_Si
23
01-24-2004 11:04 AM
memphiss13
01-19-2002 04:15 PM
