DC5 ITR Steering Wheel
Old 05-28-2004, 10:17 PM
skafia's Avatar
Default DC5 ITR Steering Wheel
I know this bolts onto 96+ EK/EJ chassis, but how does the SRS and horn bolt up? I've searched, didn't find anything...
Old 05-28-2004, 10:19 PM
skafia's Avatar
Default Re: DC5 ITR Steering Wheel (skafia)
Nevermind, found it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The JDM DC5 Wheel mounts up perfectly and the SRS plug is the same as the EK SRS plug so its plug and play.</TD></TR></TABLE>
Old 05-29-2004, 11:19 AM
chartinael's Avatar
it is very simple to put on the steering wheel. Make sure, though, when you take the old one of, that you first loosen the bolt and then put it back on. Then wiggle you old one until it pops off. If you don't you risk ruining your cable reel. Once it is loose you can just take it off.
Horn plugs on easily, SRS as well.
Before you start though, make sure to disconnect battery (neg -&gt; pos) and wait three minutes) reconnect (pos -&gt; neg) honk horn (works without ignition), turn on ignition, check SRS light. should turn off after a while.
Oh, and watch those t30 torx ... they strip easily ... ended up having to drill them open :-(
If you speak German, read this:
http://www.hondaforum.de/phpBB...light=
Old 05-29-2004, 02:40 PM
skafia's Avatar
Default Re: DC5 ITR Steering Wheel (chartinael)
Heh, very informative, thanks bro!
Honda-tech is still useful I guess!
Old 05-29-2004, 06:45 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chartinael &raquo;</TD></TR><TR><TD CLASS="quote">it is very simple to put on the steering wheel. Make sure, though, when you take the old one of, that you first loosen the bolt and then put it back on. Then wiggle you old one until it pops off. If you don't you risk ruining your cable reel. Once it is loose you can just take it off.
I don't think you can just wiggle it off. You need to yank. It's good to keep the bolt on if you decide you need to keep your teeth
Old 05-30-2004, 04:22 PM
hybridzOr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skafia &raquo;</TD></TR><TR><TD CLASS="quote">Honda-tech is still useful I guess!</TD></TR></TABLE>
haha word..
what about for a 92-95 hatch?
Old 05-30-2004, 04:33 PM
chartinael's Avatar
Default Re: DC5 ITR Steering Wheel (Hybrid Racer.)
yes, but wiggle fore and back while pulling towards you ... I braced myself with my feet on door frame and floor ....
will not fit an EG, DC2 or DAs .... beginnign EJ6 will fit ...
oh, and its "sis" :-) yyooooo
Bloody Hatch
01-28-2009 07:27 AM
DeDonDeRosa
11-29-2005 04:15 PM
BrownGSR
06-01-2005 11:52 AM
tremor86
11-14-2004 06:52 PM
mixmastabob
05-07-2003 07:16 AM
Quick Reply: DC5 ITR Steering Wheel
