Valve Springs in 2nd Gen JDM B16a
Help me out H-T
I just purchased a set of 2001 ITR cams for my B16a. I want to know if it is safe to run with the stock valve springs? Also Does the exhaust side have dual valve springs or is it just the intake? Last, is it safe to run the cams with a stock P28 ECU or will I have to get it chipped to prevent the motor from running lean up top? Thanks for reading and someone please answer these questions, because I really want to slap these cams on already. Thanks!
Modified by EG6 SiR at 5:33 PM 6/8/2004
Re: Valve Springs in 2nd Gen JDM B16a (EG6 SiR)
come on guys, somebody has to have these answers. I already searched in all forums under valve springs and B16 valve springs in the archived.
Re: Help me out H-T (EG6 SiR)
Well, I don't have answers about the valvesprings, but did you say you are using a STOCK P28 on your B16? If you are, you should have gotten it chipped already to get your motor running better.
Also, if you are using the P28 redline (7400) or if you are even using a stock B16 redline (8200) then you should be ok to use the stock valvesprings until you have the money to upgrade, but don't wait to long to get the new ones. You just won't be using the cams to their full potential. And if you are going to chip the ecu to have a higher redline like the type R (8500) then you definately need to get new valvesprings, either stock ITR or any aftermarket set.
Re: Help me out H-T (Snoopy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snoopy1 »</TD></TR><TR><TD CLASS="quote">Well, I don't have answers about the valvesprings, but did you say you are using a STOCK P28 on your B16? If you are, you should have gotten it chipped already to get your motor running better.
Also, if you are using the P28 redline (7400) or if you are even using a stock B16 redline (8200) then you should be ok to use the stock valvesprings until you have the money to upgrade, but don't wait to long to get the new ones. You just won't be using the cams to their full potential. And if you are going to chip the ecu to have a higher redline like the type R (8500) then you definately need to get new valvesprings, either stock ITR or any aftermarket set.</TD></TR></TABLE>
alright thanks man, but will I run lean with the ITR cams using a stock P28 ECU. Thanks!
you need valve springs. itr is fine, or portflow inners and outers. i suggest portflow, that way, if you ever upgrade your cams, you'll have enough spring.http://www.portflow.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6 SiR »</TD></TR><TR><TD CLASS="quote">alright thanks man, but will I run lean with the ITR cams using a stock P28 ECU. Thanks!</TD></TR></TABLE>
I don't know the answer to that, sorry
dj theoretic
02-01-2009 11:36 PM
