honda guru's please help
i have a 2000 civic si with a aem short ram intake,dc 4-1 header, and exhaust, I bought it with these items and often find the engine to sputter at low rpm's and idle back and forth rapidly between 1100 and 1400 rpm, and then when i am driving really slow(down driveway) it jolts around. i changed the cap and rotor and used some injector cleaner, but no good. does someone know what i can do?
Re: honda guru's please help (Benjithx)
is the check enigne light on?
Did you reconnect the O2 sensors?
when you installed the intake did you put back the PCV hoses?
Vac Leak?
Vac Leak?
Re: honda guru's please help (FredoSP)
i would also check things like.....ign coil...my car had some similar probs and the ign coil took a crap...after replacing...it went away...
my .02
my .02
Location: Your really lame if you dock my points, WA, 98033
Re: (Turbocoupe97)
on 99-00 si's theres theres a vacum port on the back of the Intake manifold that leads to cruise control i think. they are known to leak and cause a flucuation idle id check that out first. also check the iacv and clean it out.
Re: (Turbocoupe97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbocoupe97 »</TD></TR><TR><TD CLASS="quote">sounds like a vacuum leak to me</TD></TR></TABLE>
exactly what came to my mind
Peace
Peace
Re: (slowhatch4now)
clean out your throttle body.
you could have a dirty sensor.
if that doesnt work... spray carb cleaner around the vacuum hoses, and intake manifold, if your engine starts to choke or any diffrence at all where you sprayed, your getting a vaccum leak form there..
Re: (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI »</TD></TR><TR><TD CLASS="quote">clean out your throttle body.
if that doesnt work... spray carb cleaner around the vacuum hoses, and intake manifold, if your engine starts to choke or any diffrence at all where you sprayed, your getting a vaccum leak form there..</TD></TR></TABLE>
i never thought of that before! i always did the soap and water trick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benjithx »</TD></TR><TR><TD CLASS="quote"> low rpm's and idle back and forth rapidly between 1100 and 1400 rpm, and then when i am driving really slow(down driveway) it jolts around. </TD></TR></TABLE>
Does it only do this in low rpm, like the engine can't decide where to keep it's idle so it;s going back and forth eh ?
There are a few different reasons it might do this but most common that i've seen i would say would be a vacuum leek, bad IACV, or bad TPS.
*IACV = idle air control valve.
*TPS = throttle position sensor.
But if you say you got no codes, or no check engine light most likely it would be a vacuum, id say.
reset your ECU. i know on the 92-95s and integra's ive added parts like exhaust, intake, header, and if u don;t reset the ECU then it runs kindove bad in the lower RPM's my teg would even sometimes stall because of a faulty o2 senor reading.
warm the car up, reset ECU, and allow the car to re adjust its self.
Re: honda guru's please help (bmcc72)
I just wanted to thank everyone for quick responce and fix. It turned out to be the cruise control vac. tube. I never even saw the thing but just like the badasses you guys are i just slid that bad boy back on and and everything is back to perfect. It runs **** and has a smooth low rpm idle. YOU GUYS ARE THE BEST!!!
...beers are on me tonight boys
jeebertsab
33
09-23-2015 03:57 PM
