Low idle..Searched. Please help.
Guest
Posts: n/a
I'm pretty sure it's a problem only under braking, but I've noticed an extremely low idle recently.. especially once I've come to a stop light. I originally noticed these problems after replacing the 02 Sensor with an older one I had laying around (The CEL is off). The car is tuned up, everythings fine ignition wise. I did a search and I read that it could be a problem with the brake booster and air bubbles. I was told by the honda dealership that when working with power steering(Dumbass friend cut the hose), I'd need to bleed the brakes so as to eliminate air bubbles. I haven't done that, so could an air bubble in the brake booster cause the vaccum leak? Some other stuff I read about was adjusting idle and cleaning IACV, but I'm a little reluctant to do those since I've never done either before. Also, I just wired up an AFC last night. I'd like to iron out all these little problems before the turbo goes on, so it will be easier to fix problems associated with that. Please help me. thank you
PS: I just started the car up again and let it warm up, it stays around 500 and it somewhat rough.
Re: Low idle..Searched. Please help. (illicon2003)
theres so many things that can cause a low idle unfortunately.
Your gonna have to check those things your friends told you to
check. Below 600 idle the car will bogg and stutter
Re: Low idle..Searched. Please help. (Re3irth)
my idle is **** as well....are u running a lightened flywheel, or a chipped ecu? the 9lb wheel + a chipped p28 =hubbs b18c idle to become shitty...
