Power steering removal - The right way?
In the search I've seen the way people do it is by keeping the P/S rack and modifying it. I know that way might be cheaper but wouldn't the right way be to actually go out and buy a non P/S rack? Is there any reason why no one seems to have done this?
Seems like it would be a much better way to do it as there wouldn't be any lubrification problems and I'm pretty sure the turning ratio of the non P/S rack is different from the P/S one...
Electrician
I believe the Honda Civic CX doesn't have power steering and has manual rack and pinion. Don't quote me on this one, but I think it's right. Maybe you can swap one out?
It goes for $359.60, so you might want to hit the local junkyards and get one.
AutoZone sells Manual Rack and Pinion setups for $241, non-OEM of course.
Someone can probably chime in for more information.
Re: (2OOOsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2OOOsi »</TD></TR><TR><TD CLASS="quote">why would you want to remove ps in the first place? i used to have a car w/ out it and it is a total pain the *** parking.. </TD></TR></TABLE>
i can understand if you have a PS car and then you remove the PS and try to park it, i've had a car like this before and my boy's car is like this and its a pain in the ***, but if you have a civic that came with no PS its pretty easy to turn the wheel. i personally feel more in control of the car and can turn it with one hand for the most part, so all in all dude, don't be a *****
Re: (jetpilot)
You need a manual subframe too, if you want to do it right.
The brackets are different from ps to non ps. I had to use
a ps rack on my cx with a nonps subframe and it didnt fit
right. It worked, but I would get a lot of viberations. It was
just a temporary thing to get me home so I could fix my
manual subframe, but it sucked for that few days I had the
combination.
The manual rack has more play from side to side, I would
much rather have a power rack and subframe with the
power steering removed, then my manual one.
combination.
Re: (elwood)
you could go with the non ps rack. i think if you have a '92-'95 civic you won't have to swap the subframe. but for '96-'00 you should swap the subframe. you could run a hose up from the ps rack with a valve or fitting and occasionally put ps fluid in it if you don't want to do the swap.
Re: (pb16b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pb16b »</TD></TR><TR><TD CLASS="quote">you could go with the non ps rack. i think if you have a '92-'95 civic you won't have to swap the subframe. but for '96-'00 you should swap the subframe. you could run a hose up from the ps rack with a valve or fitting and occasionally put ps fluid in it if you don't want to do the swap.</TD></TR></TABLE>
I guess my post was a bit confusing for some people.
Sorry I didnt specify, I always forget 96+ are so much
different.
different.
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">It goes for $359.60, so you might want to hit the local junkyards and get one.
AutoZone sells Manual Rack and Pinion setups for $241, non-OEM of course.</TD></TR></TABLE>
Little trade secret : steering racks are pretty much all made by the same company. Not only from OEM to aftermarket but from car maker to car maker 241$us is still pretty expensive though, I guess I could try and find someone who'd like to swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">why would you want to remove ps in the first place? i used to have a car w/ out it and it is a total pain the *** parking..</TD></TR></TABLE>
You should of taken your car in to get inspected. A non P/S is not supposed to be painfully hard to turn. Sometimes it's just a matter of air pressure in the tires and a little adjustement on the rack guide screw. Then again I don't know what you drove, if it was a 60s land yacht or something then nevermind, but a 2000lbs Civic hatch I think I'd be fine
gotenz90640
03-19-2016 03:57 PM
