*** Help installing OMNI COILOVERS!
1 Post
Can someone guide me to some good links on how to install them?
TIA
EDIT: hey, can you help me out.
i just installed skank2 sleeve over coilovers on my front 2 OEM struts. when i drove it around, it kept making loud weird creaking or scraping noises specialy towards the front right side.
A alredy cut the lower section of the bumpstop (.5 inches) and i took out the dust covers.
do you have any idea what the problem could be??
Modified by thrty8street at 5:47 PM 6/18/2004
TIA
Re: *** Help installing OMNI COILOVERS! (thrty8street)
are they the coilover sleeves or the full coilovers?
you apply the spring compressor when you want to remove the springs.
take the whole spring/shock assembly off the car first,
then compress the spring,
remove the spirng hat,
take off the spring.. and yay.. its dissasembled.
1 Post
Re: *** Help installing OMNI COILOVERS! (Tad)
coilover sleeves.
i already have the car up and took of the wheel and i unbloted 2 bolts under the hood where the shock goes. now what?
fronts
2-12mm brakeline bolts
14mm shock fork
17mm on each end of bottom of shock fork
remove shock assembly
rear
2-14mm on top of shock
14mm on bottom of shock
14mm holding lca to brake
dissasemble and install ur new ****.
then punch yourself if you fucked it up cuz you didnt go buy a manual
14mm shock fork
rear
if you have a spring compressor, put it on tight and compress the spring until the top is slightly of the upper mount. then remove the upper mount and pull out the spring. install sleeve and spring without the compressor. do this on all four.
http://turbod16.com/viewtopic.php?t=2702 use that, it helped me.
you can also use this: http://www.c-speedracing.com/h...r.php
here a honda manual: http://www.carenthusiast.com/c...t.pdf
1 Post
Re: *** Help installing OMNI COILOVERS! (99FBPSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99FBPSi »</TD></TR><TR><TD CLASS="quote">http://turbod16.com/viewtopic.php?t=2702 use that, it helped me.
here a honda manual: http://www.carenthusiast.com/c...t.pdf</TD></TR></TABLE>
thanks alot, it helped alot
make sure you're very careful when using the spring compressor
if the spring comes loose somehow when compressed, it could fly off and ******* KILL you,
literally.
literally.
1 Post
Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad »</TD></TR><TR><TD CLASS="quote">make sure you're very careful when using the spring compressor
literally.</TD></TR></TABLE>
****, im too young to die, what do you mean by carefull? what precautions should i take?
Re: (thrty8street)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street »</TD></TR><TR><TD CLASS="quote">****, im too young to die, what do you mean by carefull? what precautions should i take?</TD></TR></TABLE>
haha, well the chances of it happening are slim,
but just make sure you get that spring compressor on there properly
Re: (Phatch99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatch99 »</TD></TR><TR><TD CLASS="quote">let us know how it goes and how it rides when you r done.</TD></TR></TABLE> yea, im thinking about getting the same coilovers.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thrty8street »</TD></TR><TR><TD CLASS="quote">
****, im too young to die, what do you mean by carefull? what precautions should i take?</TD></TR></TABLE> you should have someone help you. Don't stick your face to close to the spring.
1 Post
Re: (Phatch99)
sure will, ill get my dad to help me
Re: (thrty8street)
Are these new to the market? I've seen some threads about them here, but have never seen or heard anyone with them. How do they ride? What do they usually go for etc etc.....
would anyone like to help answer some questions i have.
i have pics and questions posted up on this site. pm me if you can help as i'm nervous about doing this install.
http://www.rit.edu/~ltk6260/suspension.html
thanks!
thanks!
1 Post
Re: (lkailburn)
hey i got 2 metal rings with my omni coilover sleeves and i was told to put them on the front 2 coilovers. im not sure where to put them. do you have like a pic or could you tell me where it goes?
you dont even need a spring compressor. what i do is put the shock on the ground pointing the hat toward a wall and have a buddy step on the shock to secure it. then i loosen the top bolt and the ****** spring flies out towards the wall. LOL, works everytime
Re: (Dimi)
You can get the spring compresor at auto zone if u dont have one. And make sure it is on the front struts real good.(they have a lot of tension on them.
