Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda Civic / Del Sol (1992 - 2000)
Reload this Page >
No oil light, car won't crank anymore...electrical problem? Help!! I give up..
Old 07-27-2004, 09:56 PM
Default No oil light, car won't crank anymore...electrical problem? Help!! I give up..
My b16a started up fine. Unitl I turned it off yesturday and it won't start again. When I turn the key to the second knodge, the oil light is not on along with the battery. Also, when I tried to start, nothing happens...and the speedometer keeps fluctuating back and fourth (going up and down, up to 70mph on the readings..)....still not sure what's wrong...
so...No oil light before or after key is turned to crank mode, speedometer fluactuating, car won't even crank....I give up..please help me....thanks
Car started fine the other day and runs fine...
setup:
b16aII
92-95 hatch
d16z6 engine wireharness
96 gsr tranny
gsr starter
eveything else is kept intact from hatch..
Modified by SkyLinER at 6:10 AM 8/2/2004
SkyLinER is offline
Old 07-27-2004, 10:17 PM
handa's Avatar
Default Re: No oil light, car won't crank anymore...electrical problem? Help!! I give up.. (SkyLinER)
bump man i'd like to know too
handa is offline
Old 07-27-2004, 10:19 PM
Donkey85's Avatar
Default Re: No oil light, car won't crank anymore...electrical problem? Help!! I give up.. (handa)
check your main fuses inside the engine bay
Donkey85 is offline
Old 07-27-2004, 10:33 PM
Default Re: No oil light, car won't crank anymore...electrical problem? Help!! I give up.. (Donkey85)
already done that...fuses are fine..
SkyLinER is offline
Old 07-27-2004, 10:54 PM
handa's Avatar
a bad distributor has nothing to do with "no crank" would it? The motor does not crank.
handa is offline
Old 07-27-2004, 11:50 PM
IVI
IVI's Avatar
a faulty distributor would not have an effect on the car cranking.
it would prevent the car from starting.
not to state the obvious, but is your battery in good condition?
IVI is offline
Old 07-28-2004, 12:25 AM
Default Re: No oil light, car won't crank anymore...electrical problem? Help!! I give up.. (IVI)
battery in good condition.
SkyLinER is offline
SICKSOLSI's Avatar
battery or starter
SICKSOLSI is offline
Old 07-28-2004, 01:42 AM
egsi's Avatar
If u have power but the dashlights dont light up, it could be the ignition swith itself.
egsi is offline
Old 07-28-2004, 02:15 AM
Default Re: No oil light, car won't crank anymore...electrical problem? Help!! I give up.. (egsi)
ignition switch was fine.
SkyLinER is offline
Old 07-28-2004, 03:02 AM
mustninty's Avatar
Dont know if this will work but what if you disconnected the battery and let the ecu reset (an hour or so). I had the exact same problem but with a different car. After asking around I found out that a faulty signal was sent to the ecu and basically tricked it into thinking something major was blown. Dont know if thats true or not but after reconnecting the battery I was good to go and the problem never came back up again.
mustninty is offline
Old 07-28-2004, 04:08 AM
Poop111444's Avatar
Default Re: No oil light, car won't crank anymore...electrical problem? Help!! I give up.. (mustninty)
Are you sure your battery is ok? Can you blast your system and get your high beams on!?
There are power distribution fuses under the hood... on my car they are different then the standard ATC style fuses. Double check those maybe? I also believe there is an ignition switch fuse, double check that one too.
Poop111444 is offline
Old 07-28-2004, 05:14 PM
Default Re: No oil light, car won't crank anymore...electrical problem? Help!! I give up.. (Poop111444)
all fuses under the hood are fine, I checked. I also switched battery too. Headlights work....even before, I could crank it.
Someone surely knows what's the problem I'm having....
SkyLinER is offline
Old 07-28-2004, 05:43 PM
just took the starter to an auto part store...it was fine.
SkyLinER is offline
Old 07-28-2004, 09:55 PM
Anyone?...
SkyLinER is offline
Old 07-28-2004, 10:44 PM
mnbv's Avatar
that sucks man, free bump. If all else fails, bring it somewhere respectable to check it out.
mnbv is offline
Old 07-29-2004, 09:03 AM
Default Re: No oil light, car won't crank anymore...electrical problem? Help!! I give up.. (mnbv)
can't bring it anywhere now...'cuz..can't get it started...
Please....someone must have had this problem before..please tell me what's going on...
SkyLinER is offline
Old 07-29-2004, 09:24 AM
crx_88_si's Avatar
check thermostat ground.
does the CEL blink at all?
crx_88_si is offline
Old 07-29-2004, 09:36 AM
nocturnaldragon's Avatar
A faster way would be to disconect the battery like you said but also step on the brake pedal for about 10 seconds. Ecu's have transisters in there like your power cap on your sterio that act as mini battery's in a sense you need to draw current from them to discharge or youll be waiting for a long time for them to drain on there own with the extreamly little current the ecu draws. (The clock wont drain it nor will the lights i belive). Give that a try but i think its a fuse under the dash or a bad connection somewhere. try hooking the starter up directly aka bypass the switch to check that and use an ohm meter on the ignition switch and just double check it. its allways something simple. but i seriously think its a bad connection somewhere............. good luck!
nocturnaldragon is offline
Old 07-29-2004, 11:14 PM
I'll try that...also, someone told me it could be the alarm that disable it...is that possible?
SkyLinER is offline
Old 07-30-2004, 03:24 AM
Poop111444's Avatar
Yes, that is very possible. The alarm is daisychained into your starter wire. It could intercept the signal from the starter wire.
Old 07-30-2004, 07:41 AM
ef-sihatch's Avatar
very possible that it is an electrical problem. check the ground connections throughout the vehicle, also take down the panel under your steering column and check voltage on the ignition wires (in your case ignition would be black w/ a yellow stripe (about 12 gauge wire)), if the car cranks its not the starter kill on the alarm otherwise it wouldn't carank at all
bump and good luck
ef-sihatch is offline
Old 08-01-2004, 09:08 PM
Default Re: No oil light, car won't crank anymore...electrical problem? Help!! I give up.. (ef-sihatch)
Well, it seems that there were signal and electricity to the starter. I am not sure why it wouldn't crank. Oh, by the way, before this I had a cel reading code 6, I think, some water temperature sensor thingy. I found out that it wasn't plugged in. It woudn't still won't crank after it was plugged in. I also had a code 14, but it started up fine even before I forgot to plug in the water temperature sensor thing. After turning the car off with that code 6, I noticed the oil light on the gauge next to the battery light didn't even turn on at all. I didn't mess with any wiring besides the engine harness. I only extended some wires and that was it..didn't touch any interior wires or wires that are attached to the body....what could be the problem? would the ecu sense something and shut the car down?
SkyLinER is offline
Old 08-03-2004, 10:45 PM
Thanks everybody..I fixed it...turns out to be a ground problem...Yes...I checked all the grounds...all of them were fine and connected...then...I had this crazy idea...I took all the ground wires out and clean them with Brake cleaner...guess what it worked...car started right up...
SkyLinER is offline
silez
05-01-2014 03:55 AM
ncskate
06-02-2005 04:03 PM
SkyLinER
08-03-2004 07:57 PM
SkyLinER
07-27-2004 10:00 PM
RCautoworks.com
12-25-2002 12:01 AM
Quick Reply: No oil light, car won't crank anymore...electrical problem? Help!! I give up..
  • Ask a Question
Question Title:
Description:
