What Brake Upgrade for Front EK (Did Search)
Old 07-28-2004, 07:12 AM
mrcch's Avatar
Default What Brake Upgrade for Front EK (Did Search)
I already have the rear discs, and a 15/16 MC with booster, and 40/40 valve, but I still need to replace the fronts due to wear and warpage. Any suggestions on what I can convert too other that upgrading to Aftermarket?
I did a search and could not come up with any good info. Thanks for any help.
mrcch is offline
Old 07-28-2004, 07:46 AM
civic23g's Avatar
Default Re: What Brake Upgrade for Front EK (mrcch)
GSR fronts bolt on. All u need is the spindle from the GSR. I got the whole hub assembly with mine so if u get it that way it will go straight on, not sure if u can use the stock one.
Tom
civic23g is offline
Old 07-28-2004, 08:40 AM
cre18's Avatar
Default Re: What Brake Upgrade for Front EK (civic23g)
or do the 99-00 si fronts, they will bolt on as well. i believe they are the same size as the gsr's too... anyone want to confirm this?
cre18 is offline
Old 07-28-2004, 08:58 AM
justanotherbluesi's Avatar
I have a 99 civic Si with stock calipers, stock size brembo cross-drilled/slotted in front,stock size cross drilled in rear, with apex kevlar pads on all four corners, and stainless brake lines, thsi set worked very well for me at auto cross, i have zero brake fade now
justanotherbluesi is offline
stupidhard
06-06-2016 11:42 AM
wfocrx
10-16-2006 10:32 AM
TypRice
12-13-2005 06:32 AM
SuperMan19
03-19-2003 09:18 PM
AcuraEL
02-22-2003 10:35 PM
Quick Reply: What Brake Upgrade for Front EK (Did Search)
  • Ask a Question
Question Title:
Description:
