hondata?
hondata?
i know this has been talked about before. when i searched all i got was how to tune. i want to know what hondata is what it would do for the car. i read that it can take off the speed limiter. right now the car pulls back at 120mph i was wondering if this will allow it to keep going.
TSPeed Factory
Re: hondata? (blacksniper)
it's basically a program that allows you to alter the fuel and ignition maps as well as many other things. then you burn all of that information onto a chip and you chip it into your ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blacksniper »</TD></TR><TR><TD CLASS="quote">i know this has been talked about before. when i searched all i got was how to tune. i want to know what hondata is what it would do for the car. i read that it can take off the speed limiter. right now the car pulls back at 120mph i was wondering if this will allow it to keep going.</TD></TR></TABLE>
http://www.hondata.com/quicktour.html <~ Should answer all your Hondata questions.
Hondata allows you to change your rev limiter, allowing you to go past your top speed. It also allows you to blow your engine up really fast if you haven't taken the proper steps to ensure that your engine is safe in that high of an RPM range.
1 Post
It lets you do more than all of that. It lets you customize your (almost) entire ecu. Fuel tables, rev limiter, vtec rpm, idle speed settings, and more.
2stepEK
Engine Management and Tuning
09-12-2008 07:42 AM
