Possible CV Joint/Axle problem...?
Old 07-27-2004, 09:11 PM
Default Possible CV Joint/Axle problem...?
Almost out of nowhere, my car (93 civic dx) started to click/bang when I turn. I know this is generally a tell-tale sign that the cv joint/enire axle needs to be replaced. However, I can't tell what side it is comming from... it makes the sound when I turn in both directions. Also, I thought I would take a look underneath the car and probably see a torn up boot and some fluid leaking, but apart from very minor cracks on the inner folds of the boots, they are relatively clean and in decent condition.
Also, the clicking is only when I am in drive. If I get some speed, put the car in neutral, and cut the wheel, the sound stops.
And like I mentioned before, the problem seemed to occur out of nowhere... I didn't hit anything nor am I making a ton of power that would cause axle failure.. it is a relatively stock Civic Dx automatic...
Any ideas as to:
if it is indeed the cv joint/axle that needs to be replaced?
what side needs to be replaced (if it is the problem)?
why did this occur?
rocket3004 is offline
Old 07-28-2004, 07:17 PM
Default Re: Possible CV Joint/Axle problem...? (rocket3004)
anyone got somewhat of an answer for me???
Old 07-28-2004, 07:40 PM
dsowers19's Avatar
When was your transmission fluid last changed? Do you check it regularly? It sounds like it might not have enough tranny fluid.
Either that or do you have power steering in your car? You might check that fluid also.
dsowers19 is offline
Old 07-29-2004, 05:33 PM
I will check that out tomorrow... last winter I drained and refilled the trans fluid (not full flush), and I checked it last week and the fluid was still the orginal color.. not brown or black, so that was quite suprising seeing as this is my daily driving car... but the level was fine... right in the cross hatches. I did not check the PS fluid, but I will.
The only thing that is tricky is that the clicking stops when the car is in neutral, which I would think either eliminates the axles as the problem, or points the finger to it, and/or something else... but the problem is that I don't know which...?
Old 07-29-2004, 05:52 PM
electronb16si's Avatar
Im pretty sure its the axles. Mine broke out of nowhere too and it did the same thing to me. How low is your car? That could be a big part of the axles breaking.
electronb16si is offline
Old 07-29-2004, 06:50 PM
ice11honda's Avatar
I didn't think DX's had power steering
ice11honda is offline
Old 07-29-2004, 08:06 PM
t25hatch's Avatar
Default Re: (ice11honda)
OUTTER CV
t25hatch is offline
Old 08-02-2004, 06:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ice11honda &raquo;</TD></TR><TR><TD CLASS="quote">I didn't think DX's had power steering</TD></TR></TABLE>
Dont think it was standard, but was an option. I have it though
Alot of ppl have been replying that similar situations occured from aftermarket suspensions, and them being too low, or not properly adjusted, but my car is completely stock in that department, except for minor impacts from curbs and other cars over it's 11yr life, but nothing major, and nothing recent in that area.
I will check on the ball joints, but did your car do that in neutral as well as in gear/drive??
Old 08-04-2004, 12:11 PM
B18Tahtaras's Avatar
If it does that during both right and left turns... it could be your Differential. or both axle's at once. also, for ***** and giggles... make sure that your lug-nuts are torqued down... ive seen that throw curve ***** at people
B18Tahtaras is offline
Old 08-04-2004, 05:06 PM
civicmon's Avatar
If you're still not sure what side it's on, try making various turns with different windows open, so try making left and right turns with drivers side window open, and same w/ pass side window.. it'll allow you to hear a little better what side it is on.
civicmon is offline
Old 08-07-2004, 04:04 PM
Default Re: Possible CV Joint/Axle problem...? (B18Tahtaras)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Tahtaras &raquo;</TD></TR><TR><TD CLASS="quote">If it does that during both right and left turns... it could be your Differential. or both axle's at once. also, for ***** and giggles... make sure that your lug-nuts are torqued down... ive seen that throw curve ***** at people</TD></TR></TABLE>
See, that is exactly what I am afraid of... I don't understand how both axles could be busted at the same time, like I said, I am totally stock, and the boots looked to be in fairly decent condition. Is there any way to check the diff to see if that is the source of the problem?
If it is one axle, would it click going both ways? What about being in neutral?
Old 08-09-2004, 11:41 AM
thePHIG's Avatar
i recently just had the same thing happen to me, clicking comming from the right side, the car is compeletly stock suspention wise, and i just had the transmition replaced 2 months ago, i posted on automotivefourms and i got a reply that it was the c/v joint and they said i needed to replace the half shaft? i checked all the boots and all are perfect, so im a lil lost as to how this would happen
thePHIG is offline
dtran002
02-22-2013 11:48 AM
frankiss123
11
05-02-2012 11:45 PM
tunerkid7
Honda Civic (2001 - 2005)
07-12-2007 11:12 AM
DanDaMan
01-21-2006 08:49 AM
ludiferino
04-04-2005 10:11 AM
Quick Reply: Possible CV Joint/Axle problem...?
  • Ask a Question
Question Title:
Description:
