hub issues, need help ASAP
* B A N N E D *
ok so i tried to install my extended studs by taking off the hub, but when i tried to get the hub off with a slide hammer, the damn thing wouldnt budge. not even a little bit. so i gave up and put everything back together and i noticed the hub/rotor had a little play. it wobbles but just barely. i figure the wheel bearing is fucked so im taking it into a shop. i dont need comments on trying to DIY this i already know.
what i need to know is if i can drive it to the nearest shop to get it fixed. (probably around 10-15 miles) is it safe or will i **** it up worse?
again i dont not need flames on DIYing this.
Re: hub issues, need help ASAP (Veritek)
That happend to me and i noticed my car was darting in dif directions, i would not recommned that you drive like that its dangerous especially at high speeds.
why don't you just take it off, and take it to the shop. it will be alot cheaper, you will only have to pay for pressing in and out. and you can have them press the studs out too and press new ones in.
I don't know about the drive it depends how bad it is.
Re: hub issues, need help ASAP (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">why don't you just take it off, and take it to the shop. it will be alot cheaper, you will only have to pay for pressing in and out. and you can have them press the studs out too and press new ones in.
I don't know about the drive it depends how bad it is.</TD></TR></TABLE>
good idea why didnt i say that?
* B A N N E D *
Re: hub issues, need help ASAP (wisjdmhonda)
yea that's an option but i dont really wanna tear apart my suspension. i may just have to do this tho
Attoir
10-14-2004 01:00 PM
