obd2>obd1 conversion ? (already searched)
Old 07-28-2004, 02:30 PM
Boosted96EK's Avatar
Default obd2>obd1 conversion ? (already searched)
Here is the situation... I have a 96 DX (D16Y7) auto.... I also have a JDMShit obd2>obd1 harness and a p28 which I believe is auto... anywho I plugged everything up and the car starts fine... the only problem is that it was idleing a little rough.... It seems that every cycle it kinda "hiccups"... I also have to mention that my O2 sensor are not on... With my stock ECU it idles fine no hiccups... Anyone have any idea why its "hiccuping"? Do I have to do anything to my dizzy? Is my timing off because of my dizzy?
Old 07-28-2004, 03:59 PM
civicHBphtride's Avatar
Default Re: obd2>obd1 conversion ? (Boosted96EK)
Did you change the pins to the ecu they must be change its two 12 and 14 i dont know on what plug though. that could be it. or if you have already did that maybe a vacum hose in the wrong placeor leak. I think on connector 32p you switch iacv 12 to 14 and 14 two 12. but im not to sure.I forgot what it was i did!
good luck!
Modified by civicHBphtride at 5:13 PM 7/28/2004
Old 07-28-2004, 04:17 PM
Default Re: obd2>obd1 conversion ? (civicHBphtride)
cant i just repin the iacv? anyone have instruction on this? or have another solution?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicHBphtride &raquo;</TD></TR><TR><TD CLASS="quote">Did you change the pins to the ecu they must be change its two 12 and 14 i dont know on what plug though. that could be it. or if you have already did that maybe a vacum hose in the wrong placeor leak. I think on connector 32p you switch iacv 12 to 14 and 14 two 12. but im not to sure.I forgot what it was i did!
good luck!
Modified by civicHBphtride at 5:13 PM 7/28/2004</TD></TR></TABLE>
Thanks for the feedback!
Old 07-29-2004, 07:05 AM
bump for more info
scookson
Engine Management and Tuning
15
10-15-2013 06:11 PM
jimbolina25
10-22-2009 09:36 AM
Hatch_Back_97
05-30-2005 10:57 PM
bambbrose
10-09-2004 08:27 AM
p10hlm
01-08-2003 08:21 PM
Quick Reply: obd2>obd1 conversion ? (already searched)
