sway bars??
Old 07-28-2004, 04:06 AM
Default sway bars??
Modified by longbeachpurplecivic at 12:47 PM 4/1/2005
longbeachpurplecivic is offline
Old 07-28-2004, 04:30 AM
asmallsol's Avatar
this is not how you should pick a sway bar.
A, your poll is retarded. Front, rear, both?
Second, just peicing parts together without thinking of your whole suspension setup and what kind of driving your into acount is retarded. For a daily driver, a del Sol VTEC rear sway could be fine, but for someone in HPDE's that would be retarded to go that small. What other suspension modifactions do you have? What spring rates? What tires and wheels do you have? These are all realivent questions
asmallsol is offline
Old 07-28-2004, 05:25 AM
egisk09
Guest
Posts: n/a
i would go with eibach with ne type of suspension
Old 07-28-2004, 05:56 AM
asmallsol's Avatar
Default Re: (egisk09)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egisk09 &raquo;</TD></TR><TR><TD CLASS="quote">i would go with eibach with ne type of suspension</TD></TR></TABLE>
good old H-T responce
Old 07-28-2004, 09:01 AM
undertheradar's Avatar
Default Re: (asmallsol)
For the rear I can only suggest the Progress bar that I have on my car. Great product!
undertheradar is offline
Old 07-28-2004, 12:33 PM
eg2hondaguy's Avatar
Default Re: sway bars?? (longbeachpurplecivic)
id say progress as well its kick ***, had it on a civic ex and on a del sol
eg2hondaguy is offline
Old 07-28-2004, 01:05 PM
. o 69 o .'s Avatar
Default Re: sway bars?? (eg2hondaguy)
I have ITR front and rear swaybars on my EG hatch. Niceness!!
. o 69 o . is offline
Old 07-28-2004, 01:15 PM
Spins's Avatar
I went with the ST setup front and rear on my eg hatch. They made a huge difference. My car is a daily driver. ST=
Spins is offline
XiiiXiii's Avatar
comptech, but they are ******* expensive now.
XiiiXiii is offline
Old 07-28-2004, 01:16 PM
ABK
ABK's Avatar
Default Re: sway bars?? (XiiiXiii)
you got to watch out for the rear sway bars they like to rip your your subframe apart. Seen it happen.
ABK is offline
Old 07-28-2004, 01:19 PM
Jon V's Avatar
do some research first.
Some models came with OEM sway bars-good place to start
There are different sizes blah blah blah
adjustable/non-adjuctable
hollow solid
you may need to reinforce your sub-frame first
Like I said do a search then do some research, then do another search and maybe you will figure out what you need all by your self. since no one else is going to be able to tell you how you like your car to handle.
Jon V is offline
Old 07-28-2004, 03:28 PM
Default Re: sway bars?? (Jon V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon V &raquo;</TD></TR><TR><TD CLASS="quote">do some research first.
hollow solid
Like I said do a search then do some research, then do another search and maybe you will figure out what you need all by your self. since no one else is going to be able to tell you how you like your car to handle.</TD></TR></TABLE>
i have.. all i wanted was a quick vote on the poll toooooooooooooo many threads to read
EFstyle
14
08-23-2007 06:18 PM
kaiba
11-24-2005 09:50 AM
Mr. 1582
01-01-2004 02:46 PM
DeDonDeRosa
07-26-2003 06:26 PM
Casual Gcode1
01-17-2003 12:36 PM
Quick Reply: sway bars??
  • Ask a Question
Question Title:
Description:
